Binary Sensor not running
I am not sure what I am doing wrong but something is wrong. I had a running Home Assistant 0.49.1 configuration where I make a communication with an SPS and via libnodave through the
command line binary_sensor.
- platform: command_line
  scan_interval: 5
  command: '../../home/pi/sps/read_sps_bin -w=00 10.0.0.100 | grep "DB5.10_Bit_0 " | grep "= 1" |wc -l'
  device_class: light
  payload_on: 1
  payload_off: 0
Now I updated to version 0.78.3 and I am too stupid to get the old config running again.
Maybe somebody can help me what I am doing wrong. Please be aware that I am far away to understand what is running all behind your great home Assist project :wink:
By the end of the day I tried with all the default configurations a ping command, even this I was not able to run. In an terminal session the command is working well but not in the Homeassistatn script.
binary_sensor:
    command_timeout: 10
    command: 'bash /home/homeassistant/.homeassistant/ping_cmd.sh'
    device_class: connectivity
    payload_on: ON
    payload_off: OFF
ping_cmd.sh
ping -W 1 -c 10.0.0.100 | grep “0%” > nul && (echo “ON”) || (echo “OFF”)
If somebody can help I will be very luck :wink:
Thanks,
Bernhard
