I’ve been using the alarm feature in Hass.IO to monitor and interact with my DSC alarm. It works wonderfully for arming/disarming and triggering events when a door opens/closes. One thing I noticed when attempting to automate a notification when it’s after midnight and my garage door is open is that the binary sensors go back to “off” or “closed” after a minute or two. I can reproduce the issue by just leaving a door or window with a sensor on it open, sure enough, I get the initial switch to “on” or “open” but then after a minute or so, it goes back to “off” or “closed”, the door/window is still OPEN!
I’ve been racking my brain on this one; any help is much appreciated.
The latest version of Hass.IO with a DSC alarm connecting to Hass.IO through an EnvisaLink 3 module.
I just integrated Envisalink with my HA setup and have a similar issue occassionally. However, mine goes from closed to open which triggers a light to come on (at night) after I’ve turned it off! It fixes itself after maybe 30 seconds.
My guess at the moment is that there is a race condition between the status update and the zone dump. Since the zone dump isn’t needed for DSC, I set the zonedump_internal to 86400 so that it only dumps once a day. While this may still have a race condition once a day, I have my HA restart daily (just because), so I think everything will get restarted and will be good.
I dug through the pyenvisalink code and it doesn’t look like there is a way to completely disable the zone dump.
You solved my problem! It works but seems like a bit of a hack to get what we need. In my case, I’m not sure how it’ll work out as I was using some automation to close the garage doors at 8PM if they were left opened by mistake. I use the alarm binary sensor as the condition of my automation, not sure it’ll work if I’ve rebooted my HASSIO system before 8PM on any given day…
