Ok, hope this is the right spot for this.
I’m trying to make a binary sensor template that turns on at one set of conditions if it’s off and turns off at a different set of conditions if it’s on. So, I created this:
- binary_sensor:
- name: "Master Bath Humidity Detected"
state: >-
{%- if states('binary_sensor.master_bath_humidity_detected') == 'off' -%}
{%- if (states('sensor.lumi_lumi_weather_humidity_2') | float >= 50) and (states('sensor.lumi_lumi_weather_humidity_2') | float - states('sensor.lumi_lumi_weather_humidity') | float > 10) -%}
on
{%- endif -%}
{%- else -%}
{%- if (states('sensor.lumi_lumi_weather_humidity_2') | float < 50) or (states('sensor.lumi_lumi_weather_humidity') | float - states('sensor.lumi_lumi_weather_humidity_2') | float >= 0) -%}
off
{%- endif -%}
{%- endif -%}
So the idea is that if the binary sensor is off, and then Bathroom Humidity (lumi_lumi_weather_humidity_2) goes above 50 and the difference between the Bathroom Humidity and the Bedroom Humidity (lumi_lumi_weather_humidity) is greater than or equal to 10, turn the binary sensor on.
If the binary sensor is on, and the Bathroom Humidity goes below 50 or the Bathroom Humidity is equal to or below the Bedroom Humidity, turn the binary sensor off.
So looking at the history I’m getting this:
Turned off triggered by state of Master Bathroom Sensor Humidity changed to 68.5
2:18:40 PM - 27 minutes ago
Turned on triggered by state of Master Bathroom Sensor Humidity changed to 68.5
So it turns on then immediately turns off.
I paste the template in the Developer Tools and it seems to work fine.
Can anyone help??
Thx
