Binary_sensor template not updating
binary_sensor.garagedoorpi state changes from on to off successfully. However, my binary_sensor.garage_door state remains “Closed” and doesn’t change when garagedoorpi does.
Any suggestions?
thanks
binary_sensor:
  - platform: remote_rpi_gpio
    host: xxxx
    #pull_mode: UP
    invert_logic: true
    ports:
      17: garagedoorpi
    sensors:
      garage_door_status:
        value_template: "{%if states.binary_sensor.garagedoorpi.state == 'Off' %}Closed{% elif states.binary_sensor.garagedoorpi.state == 'On' %}Open{% endif %}"
        friendly_name: 'Garage Door'
        device_class: garage_door
Try "{% if
That is with a space between % and if
The trick with all these things is to use the template editor to troubleshoot every time…
Alternatively this should work. Yours may not. Binary sensor templates expect true/false results.
    sensors:
      garage_door_status:
        entity_id: binary_sensor.garagedoorpi.state
        value_template: "{{ is_state('binary_sensor.garagedoorpi.state', 'on') }}"
This template will evaluate to true/false:
The device class will convert it to open/closed for display in the front end.
Personally, I’d go with @tom_l’s solution. But the reason your template isn’t updating is because you’re checking against the states 'On' and 'Off'. Removing the capital O’s and replacing them with lowercase will make your template work. The second reason your template isn’t working is because binary sensors only accept true/false as an answer. You’re returning ‘closed’ and ‘open’. Both of those in the jinja and python world resolve to TRUE. So even if you fix the states, the template still won’t work as expected. Which is why you should go with @tom_l’s solution.
Whenever you are writing a template, you need to look at the states page. The states page will display the state of any sensor. What you see in the UI is a translated state. That typically means that the UI state isn’t the real state, it’s just a pretty version of the real state or a pretty translated version of the real state.
Is there an expected delay for the template to update? I made the suggested change and when I change my gpio state, binary_sensor.garagedoorpi changes instantly in Lovelace. However, the template doesn’t change states. It remains as “Closed”.
I also noticed that remote_rpi_gpio platform doesn’t support device_class. Seems like a possible enhancement.
binary_sensor:
    host: xxxxx
    #pull_mode: UP
    invert_logic: true
    ports:
      17: garagedoorpi
    sensors:
      garage_door_status:
the template should be
"{{ is_state('binary_sensor.garagedoorpi', 'on') }}"
There was a typo in @tom_l’s template that we all overlooked
yup, that works great. thanks
