I need help with a template. I want a binary sensor that turns on if the difference between 2 temperature sensors is greater than 3.
At the moment I have the following in configuration.yaml
sensors:
kitchen_minus_living:
entity_id:
- sensor.kitchen_temp
- sensor.temp_inside_upstairs
value_template: >-
{% set kitchen = states.sensor.kitchen_temp.state|float %}
{% set living = states.sensor.temp_inside_upstairs.state| float %}
{{ (kitchen - living)|round(1) }}
binary_sensor:
sensors:
cooking:
friendly_name: "Cooking"
value_template: "{{ states('kitchen_minus_living')|float > 3.0 }}"
I honestly don’t understand anything about the language used in templates so I would greatly appreciate any help ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=9)
Try this:
binary_sensor:
sensors:
cooking:
value_template: >
{% set kitchen = states('sensor.kitchen_temp')|float %}
{% set living = states('sensor.temp_inside_upstairs')| float %}
{{ (kitchen - living)|round(1) > 3 }}
since I am having a similar issue maybe someone can point me in the right direction.
I would like a binary sensor to measure a difference between 2 signal strength values with a twist.
Since the signal is always changing i need some kind of tolerance. This is the code I have but i need the “else” to be like last known state.
It kinda works as a normal sensor but produces so much values. I Just need “Inside” and “Outside” so binary would be much better. With the tolerance of like 10dB and before that no change.
binary_sensor:
ble_cat_pos_diff:
friendly_name: Cat Position
entity_id:
- sensor.ble_doctor_rssi_value
- sensor.window_ble_doctor_rssi_value
value_template: >-
{% set catd_rssi = states.sensor.ble_doctor_rssi_value.state|float %}
{% set catw_rssi = states.sensor.window_ble_doctor_rssi_value.state| float %}
{% set cat_pos = (catd_rssi - catw_rssi)|round(1) %}
{% if ((catd_rssi - catw_rssi)|round(1) > 10) %}
Cat Inside
{% elif ((catd_rssi - catw_rssi)|round(1) < 0) %}
Cat Outside
{% else %}
# [{last state}]?
{% endif %}
In case anyone is searching for this here is my solution that works as expected.
I don’t know if it is the best solution. And i miss some initialise Value because i only update (trigger) when the difference is 10db apart.
It is in the configuration.yaml under template:
- trigger:
- platform: numeric_state
entity_id:
value_template: >
{% set indoor = states('sensor.ble_doctor_rssi_value') | float %}
{% set outdoor = states('sensor.window_ble_doctor_rssi_value') | float %}
{% set tmp = ((indoor - outdoor) | round(1)) %}
{{tmp}}
above: 9
entity_id:
value_template: >
{{tmp}}
below: 0
- name: "Cat Position"
state: >
{% if tmp > 9 %}
{{ "Cat is Home" }}
{% elif tmp < 0 %}
{{ "Cat is Outside"}}
{% endif %}
