Hi! General novice here having trouble with what I presume is some simple ESPHome configurations.
In a previously project I had used a pressure sensor mat (normally closed) connected to a esphome32 board in order to trigger some automations. This worked great for a couple of months. However, a couple of weeks ago it stopped working. After some trial and error I just decided to purchase a new esphome32 board and write the same code over. However, when I open the logs for the new esphome32 device, it’s not registering (sending state on/off) when pressure is applied (despite the code being the same). I’m a little confused on what is happening and after a couple weeks of reading, watching YouTube, and trial and error, I’ve come here.
I’ve pasted below the yaml for the board, a screenshot of the logs, as well as the placement of the pins on the board itself. Any help on why this would not be registering would be appreciated!
esphome:
friendly_name: Doggy-Door-Mat-Inside-2
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxxxxxx"
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-Ca0550"
password: "xxxxxxxxxx"
captive_portal:
binary_sensor:
platform: gpio
pin:
number: 5
inverted: true
mode:
input: true
pullup: true
name: Doggy Door Mat Inside 2
