polcape
(Paolo)
August 30, 2018, 12:05pm
1
I have setup the SPC component and all working fine: all binary sensor are loaded and I can activate/deactivate the alarm by hass.
I have notice that there is no history on SPC loaded binary sensor? Other binary sensor have the history…
Why this behavior?
I have enabled history component and there isn’t any exclusion or inclusion customization.
polcape
(Paolo)
August 30, 2018, 12:35pm
3
petro:
have you restarted?
Yes, I have restarted many times…
But in history I have the message “No history found”
I use spc component of hass 0.58 in hass 0.77 because the actual not work (I found here the workaround fix).
petro
(Petro)
August 30, 2018, 12:37pm
4
Have you left home assistant running so it can build the history?
polcape
(Paolo)
August 30, 2018, 12:39pm
5
Yes, It is more than one day…
Some sensor are changed many times…
I have history in all sensor but not in SPC derived
petro
(Petro)
August 30, 2018, 12:40pm
6
Hmm, not sure. Is this just basic history with no configuration?
polcape
(Paolo)
August 30, 2018, 12:42pm
7
Yes. In my configuration.yaml I have
# Discover some devices automatically
discovery:
# Enables support for tracking state changes over time
history:
# Enable recorder component
recorder:
# View all events in a logbook
logbook:
polcape
(Paolo)
August 31, 2018, 12:37pm
8
Hi @petro ,
any suggestion to see if the data are not recordered?
petro
(Petro)
August 31, 2018, 12:39pm
9
I’m not sure where to begin to be honest. It should appear.
polcape
(Paolo)
August 31, 2018, 12:41pm
10
OK, thanks. I hope that someone help me to debugging this problem.
Do you use SPC or not?
I think that the problem was the recorder component, not history one.
Did anyone get anywhere with this I have the same issue.
