Hi!
I’m trying out the rather new binary_sensor. I’ve set it up to switch on if above threshold.
Then I’m having an automation that checks if the binary_sensor has been “off” for 10 minutes, and if so sends a HTML5 notification.
The problem is that HASS won’t stop sending the notifications (sends a new one every minute without stop - the sensor feeding the binary_sensor sends new data every minute). My expectation was that one notification would be sent, and then nothing more until it change it’s state.
Here’s my configuraion for the parts:
binary_sensor:
- platform: threshold
threshold: 50
type: upper
entity_id: sensor.temp
automation:
- alias: ‘TEST-temp’
platform: state
entity_id: binary_sensor.temp
state: ‘off’
for:
minutes: 10
action:- service: notify.html5
data_template:
message: ‘TEST: temp’
And here are some logging data:
FROM LOGBOOK:
15:55
TEST-temp has been triggered
15:54
15:53
15:52
15:51
15:50
FROM HOME-ASSISTANT.LOG:
16-12-16 15:40:16 homeassistant.core: Unable to remove unknown listener <function async_track_state_change..state_change_listener at 0x7f3f3d381a60>
16-12-16 15:58:17 homeassistant.core: Unable to remove unknown listener <function async_track_state_change..state_change_listener at 0x7f3f3e722d90>
