Hey folks
I wonder if anyone has experience of trend sensors? I have a slightly dodgy switch on my boiler, and I want to know if the temperature is still rising after Hassio things it has sent the off command (basically triggering an alert).
I have set up a sensor as follows:
binary_sensor:
- platform: trend
sensors:
temp_rising:
entity_id: sensor.livingroom_temp_temperature
min_gradient: 0.000333333333
But, I’m seeing these results… Am I missing something obvious?
- The temperature is rising fast (meaning my boiler switch has failed) but the trend sensor is showing as Temp Rising Off… it does work sometimes, as you can see.
- Temperature has risen 19.3-20.7 in one hour.
- I’ve set the sensor to trigger at 1.2 degree rise per hour (1.2/(60*60))
