Bind a picture element icon to a sensor in Lovelace UI
I have the following card in Lovelace UI:
Untitled
        - type: icon
          icon: mdi:pause
          tap_action:
            action: call-service
            service: vacuum.pause
            service_data:
              entity_id: vacuum.vacuum_1st_floor
          hold_action:
            action: none
          entity: vacuum.vacuum_1st_floor
          style:
           top: 93%
           left: 35%
           color: '#3090C7'
        - type: icon
          icon: mdi:play
          tap_action:
            service: vacuum.start
            service_data:
          hold_action:
            action: none
          style:
           top: 93%
           left: 20%
           color: '#3090C7'
My issue is that I just can’t get those two icons replaced with a single icon that changes the status based on vacuums status. This is what I’ve come up with for now, but I can’t get it to work. In addition I need the tap_action to change with the icon. So I need to send the .start command when the play-icon is shown and .pause when the pause-icon is visible…:
    sensors:
      vacuum_2nd_floor_start_pause:
        friendly_name: Start/Pause
        entity_id:
          - vacuum.vacuum_2nd_floor
        value_template: '{{ states.vacuum.vacuum_2nd_floor.attributes.status }}'
        icon_template: >
          {% set val =  states.vacuum.vacuum_2nd_floor.attributes.status  %}
          {% if val == 'Cleaning' %}
            mdi:pause
          {% elif val == 'Returning home' %}
            mdi:pause
          {% else %}
            mdi:play
          {% endif %}
Is a sensor the right way of doing this? How can I tell the picture-element to use whatever mdi icon comes back from the sensor? Any tips are highly appreciated, been spending 8+ hours on this now, so beginning to go kind of crazy :stuck_out_tongue:
Bump. No ideas on how this can be done?
