Hello guys,
I try to make this simple project because I have another project ( an irrigation programmer with 4 x relays, 1 x dth 22 , 1 x drop sensor and 1 x moister sensor) connected with node red and I want to migrate to home assistant. This project works very good.
I try from a week to figure out why my new project is not work. I use a ESP8266 NodeMCU the home assistant is installed on a laptop with Ubuntu and I use a docker. The ESP is connected on WiFi, the mqtt broker show me the connection but when I press button on the home automation interface nothing happens. On ESP I connect on the pin D2 a led.
This is the cod from arduino:
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// Update these with values suitable for your network.
const char* ssid = "Archer";
const char* password = "@test@";
const char* mqtt_server = "192.168.100.149";
WiFiClient espClient;
PubSubClient client(espClient);
int SwitchedPin = D2;
String switch1;
String strTopic;
String strPayload;
void setup_wifi() {
Serial.begin(115200);
delay(100);
// We start by connecting to a WiFi network
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
void callback(char* topic, byte* payload, unsigned int length) {
payload[length] = '\0';
strTopic = String((char*)topic);
if(strTopic == "ha/switch1")
switch1 = String((char*)payload);
if(switch1 == "ON")
Serial.println("ON");
Serial.println(strTopic);
Serial.println(strPayload);
digitalWrite(SwitchedPin, HIGH);
client.publish("ha/switch1", "ON");
else
Serial.println("OFF");
digitalWrite(SwitchedPin, LOW);
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("arduinoClient")) {
Serial.println("connected");
// Once connected, publish an announcement...
client.subscribe("ha/#");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void setup()
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
pinMode(SwitchedPin, OUTPUT);
void loop()
if (!client.connected()) {
reconnect();
client.loop();
This is the output from serial:
Connecting to Archer
WiFi connected
IP address:
192.168.100.151
Attempting MQTT connection...connected
This is the configuration yaml:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Light
switch:
- platform: mqtt
state_topic: "ha/switch1"
command_topic: "ha/switch1"
qos: 0
payload_on: "ON"
payload_off: "OFF"
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# MQTT broker
mqtt:
broker: 192.168.100.149
port: 1883
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
This is the configure UI:
entity: switch.switch1
hold_action:
action: more-info
icon_height: 30px
show_icon: true
show_name: true
tap_action:
action: toggle
type: button
This is the conf of mqtt:
logins: []
anonymous: true
customize:
active: false
folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
And this is the mqtt broker logs:
[10:54:23] INFO: Setup mosquitto configuration
[10:54:23] WARNING: SSL not enabled - No valid certs found!
[10:54:23] INFO: No local user available
[10:54:23] INFO: Initialize Hass.io Add-on services
[10:54:23] INFO: Initialize Home Assistant discovery
[10:54:23] INFO: Start Mosquitto daemon
1588924463: mosquitto version 1.6.3 starting
1588924463: Config loaded from /etc/mosquitto.conf.
1588924463: Loading plugin: /usr/share/mosquitto/auth-plug.so
1588924463: |-- *** auth-plug: startup
1588924463: ├── Username/password checking enabled.
1588924463: ├── TLS-PSK checking enabled.
1588924463: └── Extended authentication not enabled.
1588924463: Opening ipv4 listen socket on port 1883.
1588924463: Opening ipv6 listen socket on port 1883.
1588924463: Opening websockets listen socket on port 1884.
1588924463: Warning: Mosquitto should not be run as root/administrator.
1588924465: New connection from 172.30.32.1 on port 1883.
[INFO] found homeassistant on local database
1588924465: New client connected from 172.30.32.1 as auto-7549CD0D-61C7-A608-7AD8-41810E6EF5D4 (p2, c1, k60, u'homeassistant').
1588924467: New connection from 192.168.100.151 on port 1883.
1588924467: New client connected from 192.168.100.151 as arduinoClient (p2, c1, k15).
Thanks for help.
