Bitcoin platform errors?
Anyone else having issues with the Bitcoin platform lately?
I’m on 0.103.2
Here’s the error from my log:
Log Details (ERROR)
Fri Dec 20 2019 07:15:08 GMT-0500 (Eastern Standard Time)
Error while setting up platform bitcoin
  File "/usr/local/lib/python3.7/site-packages/blockchain/util.py", line 26, in call_api
    response = urlopen(base_url + resource, payload, timeout=TIMEOUT).read()
  File "/usr/local/lib/python3.7/urllib/request.py", line 222, in urlopen
    return opener.open(url, data, timeout)
  File "/usr/local/lib/python3.7/urllib/request.py", line 531, in open
    response = meth(req, response)
  File "/usr/local/lib/python3.7/urllib/request.py", line 641, in http_response
    'http', request, response, code, msg, hdrs)
  File "/usr/local/lib/python3.7/urllib/request.py", line 569, in error
    return self._call_chain(*args)
  File "/usr/local/lib/python3.7/urllib/request.py", line 503, in _call_chain
    result = func(*args)
  File "/usr/local/lib/python3.7/urllib/request.py", line 649, in http_error_default
    raise HTTPError(req.full_url, code, msg, hdrs, fp)
urllib.error.HTTPError: HTTP Error 403: Forbidden
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 150, in _async_setup_platform
    await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
    return fut.result()
  File "/usr/src/homeassistant/homeassistant/components/bitcoin/sensor.py", line 62, in setup_platform
    if currency not in exchangerates.get_ticker():
  File "/usr/local/lib/python3.7/site-packages/blockchain/exchangerates.py", line 17, in get_ticker
    response = util.call_api('ticker' if api_code is None else 'ticker?api_code=' + api_code)
  File "/usr/local/lib/python3.7/site-packages/blockchain/util.py", line 30, in call_api
    raise APIException(handle_response(e.read()), e.code)
blockchain.exceptions.APIException: <!doctype html><meta charset="utf-8"><meta name=viewport content="width=device-width, initial-scale=1"><title>403</title>403 Forbidden
So it seems to have cleared itself up. I was doing some other edits and ended up needing to retstart HA a bunch of times. On about the 4th restart (which also came after rebooting the entire NUC), it started working again.
