Bitcoin to google say issue
I am trying to cast the bitcoin price to my google home device group if it is above a certain value at a particular time in the day. The automation is not respecting the bitcoin price, and not stating the actual value of the bitcoin. What am I doing wrong? I am fairly new to hass
configuration.yaml
  - platform: bitcoin
    display_options:
      - exchangerate
automations.yaml
- alias: 'Bitcoin value exceeds 16000'
     - platform: time
       at: '18:00:00'
     - platform: numeric_state
       entity_id: sensor.bitcoin
       value_template: '{{states.sensor.bitcoin.state.attributes.exchangerate}}'
       above: 16000
      service: tts.google_say
      entity_id: media_player.all
           message: 'Bitcoin is trading at {{state.attributes.exchangerate}}'
           language: 'en'
           cache: false
Try changing
to
message: 'Bitcoin is trading at {{state.sensor.bitcoin.attributes.exchangerate}}'
That did not work. It is still reading out “state dot sensor dot bitcoin dot attributes dot exchangerate”.
Two more changes should get you up and running :slight_smile:
You’re creating a template, so you need to change
to
data_template:
and
should be
{{states.sensor.bitcoin.attributes.exchangerate}}
A typo introduced by me :blush:
Apologies for the delayed response. I am not sure how I am creating a template (is it because I am specifying value_tempalate?), but this change did not work. In fact it did not even trigger the casting at all. Any other ideas?
Hmmm,
Can you post your code for the automation and the sensor please ?
I have removed identifying information using the tag.
automations.yaml (505 Bytes)
configuration.yaml (2.0 KB)
Your indenting was out and the sensor name incorrect.
The below code works for me ( changing the media player, at least when I force the trigger ) :slight_smile:
  - platform: time
    at: '16:03:00'
    value_template: '{{states.sensor.exchange_rate_1_btc.state}}'
    above: 19000
  - service: tts.google_say
    data_template:
      message: 'Bitcoin is trading at {{states.sensor.exchange_rate_1_btc.state}}'
      cache: false
Thanks! This worked!!
