Bitdefender Box 2 and Home Assistant
I recently added a Bitdefender Box 2 to my setup and have installed a fresh copy of Hassio to my RPi3. Does anyone know how to configure port forwarding when I’m using the Box? I thought I had to configure it through the Central app and that specific device, but it doesn’t seem to work.
For instance, I set up DuckDNS. When I went into the Hassio device in the Central app, I added a port forwarding rule to it. I wasn’t quite sure how to configure it, but I used WAN port 443 and LAN port 8123 with the TCP protocol.
Everything appeared to function properly until I reset HA. Now, it refuses to connect through either my DuckDNS URL or its IP address. The IP address returns an “empty response” error.
Has anyone else encountered this and been able to get it to work correctly? My thought is that I don’t have the port forwarding set up correctly, but I can’t find anything online that tells me anything other than the Box is capable of it.
This is a very, very old post, but just in case anyone is still grappling with it, you have to set up port forwarding twice: once in the ISP router to forward 8123 to the Bitdefender Box and once in the Box to forward it to HA. Worked for me, anyway.
