taHC81
(Ta Hc81)
January 12, 2024, 10:23am
1
Hello, I’ve got 2 sensors from modbus device, and I need to merge them info single float32 sensor.
sensors:
- name: "CS Vbus1"
unique_id: cs_vbus1
slave: 90
address: 0
input_type: holding
data_type: uint16
precision: 0
scan_interval: 3
- name: "CS Vbus2"
unique_id: cs_vbus2
slave: 90
address: 1
input_type: holding
data_type: uint16
precision: 0
scan_interval: 3
And what I need:
cs_vbus1 = 54526 / 0xD4FE / b1101010011111110
cs_vbus2 = 16807 / 0x41A7 / b0100000110100111
b0100000110011111 b1101110100101111 / 0x41A7D4FE = 20.9790000916
Basically, I need to create float32 variable, assign cs_vsbus1 to it, bitshift left by 16 and logical OR cs_value2. How to create such template sensor? Thanks!
taHC81
(Ta Hc81)
January 12, 2024, 11:33am
2
Found that!
- name: "CS Vbus"
unique_id: cs_vbus
slave: 90
address: 0
input_type: holding
data_type: float32
swap: word
precision: 5
scan_interval: 3
Returns valid voltage: 20.97800V
Troon
(Troon)
January 12, 2024, 1:09pm
3
Realise you’ve solved it, but another way:
{% from 'ieee754.jinja' import ieee754_float %}
{{ ieee754_float("41A7D4FE") }}
Returns 20.979000091552734.
Using your existing sensors, assuming they contain decimal values as strings:
{{ ieee754_float('%0x%0x' %
(states('sensor.cs_vbus2')|int(0),
states('sensor.cs_vbus1')|int(0)) }}
taHC81
(Ta Hc81)
January 12, 2024, 1:39pm
4
Thanks, not needed anymore, now I don’t need any calculations, was just a question of correct configuration of a sensor.
sadicim
(Ego)
June 2, 2024, 7:05am
5
Thanks for the tip, the Jinja macro has just saved my day, especially for converting from float 2 hex to get little endian format from user input.
{% from 'ieee754.jinja' import float_ieee754_single %}
{{ float_ieee754_single(FLOAT NUMBER) }}
