I tried to install espHome to this device and all worked well while using an external power supply.
When I disconnect the serial and the external power supply i’m not able to start it anymore. Connecting the 230V AC results in multiple relay noise, and it seems that the device continue to reboot.
I think it’s related to the big cpu power consumption that causes a blackout with the small internal AC-DC supply. If I disconnect 230V and reconnect 3.3V external power supply all starts working…
Following my yaml, how can I modify it to avoid that problem?
esphome:
bk72xx:
board: cb2s
# Enable Home Assistant API
api:
logger:
ota:
platform: esphome
wifi:
networks:
- ssid: "Dim-GB0"
- ssid: "Dim-GB"
ap:
ssid: "testDIY Fallback Hotspot"
password: "asdasdasd"
binary_sensor:
- platform: gpio
pin:
number: P23
mode:
input: true
pullup: true
on_press:
- switch.toggle: aubespm01
- platform: gpio
pin:
number: P24
mode:
input: true
pullup: True
on_press:
on_release:
- platform: status
- platform: wifi_signal
update_interval: 10s
- platform: uptime
- platform: copy
source_id: wifi_signal_db
name: "WiFi Signal Percent"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "%"
- platform: bl0942
uart_id: uart_bus
voltage:
current:
power:
filters:
multiply: -1
energy:
frequency:
accuracy_decimals: 2
update_interval: 60s
output:
- platform: gpio
pin: P8
switch:
- platform: gpio
pin: P26
restore_mode: RESTORE_DEFAULT_OFF
on_turn_on:
then:
- output.turn_on: led
on_turn_off:
then:
- output.turn_off: led
captive_portal:
uart:
tx_pin: P11 #TX
rx_pin: P10 #RX
baud_rate: 4800
stop_bits: 1
