Has anyone manged to get BL0942 metering IC configured with esphome?
I did enable some debug and it always return “Serial not available”
void BL0940::loop() {
DataPacket buffer;
if (!this->available()) {
ESP_LOGW(TAG, "Serial not available");
return;
if (read_array((uint8_t *) &buffer, sizeof(buffer))) {
if (validate_checksum(&buffer)) {
received_package_(&buffer);
} else {
ESP_LOGW(TAG, "Junk on wire. Throwing away partial message");
while (read() >= 0)
I enabled uart as below
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
delimiter: "\n"
sequence:
- lambda: UARTDebug::log_hex(direction, bytes, ':');
I can see that 50:AA is written
[D][uart_debug:114]: >>> 50:AA
mateine
3
If this gets merged, in the next release of esphome ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=10)
@mateine is this merged? I tried but it says Platform not found: 'sensor.bl0942'.
Got it working by adding below.
external_components:
- source:
type: git
url: https://github.com/esphome/esphome
ref: dev
components: [bl0942]
mateine
5
Merged but not released yet. It should be out in the next EspHome version.
Btw, I didn’t know about external_components, thanks for sharing!
TTP
(TTP)
6
I just ordered two Aubess Smart Switch 16A with Power Monitoring. Seems to be BL0942.
I never used ESPHome before. How did you flash it?
Flashed via serial (soldered some cables to the chip) and this esphome port ESPHome - LibreTuya
