Black PIR sensor
For some reason it’s very hard to find a black PIR sensor (at least the fresnel lens which encloses it).
I’ve come across a few black ones like the one here but a complete assembled is almost impossible to find.
I would like to add a few in my new house, but having them in white just sticks out and draws too much attention.
Thanks for the help.
Pieter
I think most home have light colored walls & ceilings so the manufacturers assume white sensors would draw the least attention in the majority of cases.
This a black movement sensor inside or out?
Ok, so there isn’t a technical reason why this isn’t common in a black colour.
I can find some products but they seem more like they’re quite high end, and expensive compared to the white ones.
https://www.dmlights.be/niko_bewegingsmelder_180__16m_230v_ip54_zwart~07ZLH?gclid=Cj0KCQjwsZKJBhC0ARIsAJ96n3XURXYmGNsO8N7_5z0-Aovo9J6QFqHIiP9kQk5til1MLdxd08FYDGoaAjZbEALw_wcB
Like these two. The last one is KNX enabled but costs like €250, which is a bit over budget defenitely if you want to use a lot of those.
… so €250 was for the white one, the black one is €303,70 lol
Any suggestions where to find some affordable black ones are more than welcome.
Pieter
