Hi!
I try to build custom component for a DS3502 chip. But I already fail to build an empty custom component as desrcibed at Custom Output — ESPHome :
#include "esphome.h"
using namespace esphome;
class MyDs3502 : public Component, public FloatOutput {
public:
void setup() override {
// This will be called by App.setup()
void write_state(float state) override {
// state is the amount this output should be on, from 0.0 to 1.0
// we need to convert it to an integer first
This does oviously nothing. But including it like
esphome:
libraries:
- Wire
- SPI
- adafruit/Adafruit BusIO@^1.11.6
- adafruit/Adafruit DS3502@^1.0.1
includes:
- MyDs3502.h
does not compile:
Compiling /data/esp-01s-solar-board/.pioenvs/esp-01s-solar-board/src/main.cpp.o
In file included from src/main.cpp:61:
src/MyDs3502.h:4:55: error: expected class-name before '{' token
4 | class MyDs3502 : public Component, public FloatOutput {
src/MyDs3502.h:10:8: error: 'void MyDs3502::write_state(float)' marked 'override', but does not override
10 | void write_state(float state) override {
*** [/data/esp-01s-solar-board/.pioenvs/esp-01s-solar-board/src/main.cpp.o] Error 1
========================== [FAILED] Took 2.19 seconds ==========================
What am I doing wrong?
Best regards
Pascal
