Blank groups after update
After updating to 79 from 77.1 a lot of groups are empty. Multiple cache clears did not work.
I have a lot errors similar to this:
https://xxx.duckdns.org/frontend_latest/app-084b7564.js:91:305 Uncaught TypeError: Cannot read property 'binary_sensor' of undefined
Seems like a little bit of everything is a bit off. Tried rolling back to 77.1, but seemed to fail.
I get this sometimes, clearing the browser cache helps
Like I posted, multiple cache clears have not worked. It is the same behavior on all devices that I have. First clue was on iOS app not reacting to tap action. It is as if the entities are not there, but automations can still control the entities.
Are you running custom ui? Probably need to update that in that case.
Good call. After commenting out any custom UI and restarting it seems to be back.
Thanks!!
