Blank hardware page after updating to 2022.8.7
Yesterday I updated my installation from core version 2022.6.7 to 2022.8.7. All seems to work, but my hardware page under Settings > System > Hardware is blank/empty. I am running Home Assistant in a docker container (docker version 20.10.17) with supervisor-2022.08.5 (using Ubuntu, I know, unsupported). However, the URL path /hassio/system/info works and shows me information about Core, Host and Supervisor. In the log I am seeing an “http://ip-address:8123/config/hardware:0:0 Uncaught” error, but I don’t know if it is related to the hardware page.
Any hints how to get a none-empty hardware page?
Same as me. With Docker installation, hardware page is blank, but no lines in log.
Do you get at least a ‘virtual machine’ tab?
If you hit the 3 dots in the upper right corner you can reveal all hardware:
I do have this little menu and “all hardware” brings me to a kind of popup window with devices. But I guess there should be more on the page itself.
I only have ‘virtual machine/ ova’
but the 3 dots show me all hw:
I have the same issue. Home Assistant Supervised installed on Debian OS running on Raspberry PI
On 2022.9.0 there is :smiley:
But for a list of hardware you need to use the 3 dots…at least for VM’s
I am in the same boat… my hardware screen is completely blank but the 3 dots menu works.
## System Information
version | core-2022.8.7
installation_type | Home Assistant Supervised
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.10.5
os_name | Linux
os_version | 5.10.0-16-amd64
arch | x86_64
timezone | America/Chicago
config_dir | /config
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
GitHub API Calls Remaining | 4897
Installed Version | 1.27.1
Stage | running
Available Repositories | 1108
Downloaded Repositories | 15
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Debian GNU/Linux 11 (bullseye)
update_channel | stable
supervisor_version | supervisor-2022.08.6
agent_version | 1.2.2
docker_version | 20.10.12
disk_total | 218.1 GB
disk_used | 16.8 GB
healthy | true
supported | true
supervisor_api | ok
version_api | ok
installed_addons | Backup Hassio to Google Drive (1.7.2), Dropbox Sync (1.3.0), Duck DNS (1.15.0), File editor (5.4.0), Log Viewer (0.14.0), RPC Shutdown (2.2), WireGuard (0.7.0), SSH & Web Terminal (12.0.2), Samba share (10.0.0), TasmoAdmin (0.20.0), Glances (0.16.0), Check Home Assistant configuration (3.11.0), DHCP server (1.3.0), Network UPS Tools (0.11.0), Samba Backup (5.1.2), Portainer (2.0.0), Home Assistant Google Drive Backup (0.108.4), SDR to Home Assistant (0.1.14b), Mosquitto broker (6.1.3)
</details>
<details><summary>Dashboards</summary>
dashboards | 1
resources | 7
views | 15
mode | storage
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | September 6, 2022 at 9:04 PM
current_recorder_run | September 6, 2022 at 4:04 PM
estimated_db_size | 264.45 MiB
database_engine | sqlite
database_version | 3.38.5
</details>
<details><summary>Sonoff</summary>
version | 3.2.0 (38856d1)
cloud_online | 0 / 0
local_online | 0 / 0
</details>
I’m using 2022.9.4 and I’m seeing an empty page as well at first. But after 5+ seconds the charts appear.
Normally if something does not appear or start working within a second or two I close the screen. So I never waited longer than that. But it does work, albeit with a (huge) delay.
I have the same issue running 2022.11.4 container, the hardware statistics show up after ~5s, but the three dot menu does not show.
Also the network page is blank and stays blank. Anyone else experiencing this? This currently prevents me from changing the internal_url from the host IP…
Hi, I have the same issue, also 2022.11.4 container and no three dot menu.
