Hi Guys
I’m trying to access my unused entities screen but it just shows a blank page.
Am I missing something here, was there a few updates ago?
Hi Guys
Have you tried CTRL+F5 to refresh your browser cache?
I have yes unfortunately
I have the exact same problem. I’ve tried using different browsers on different platforms. No luck.
If no one comes up with a solution you should raise a new issue here (I checked that there is no relevant one open):
In my case I had an unused page in my configuration. Removing that page allowed the unused entities to populate.
I had a null badge that I had to remove by using the raw config editor. Once I removed that, my unused entities page appeared.
It seems that is related to badge as @rippedwarrior mentioned, i was deleting some badges, sudenly all badges disapeard from the configuration (where you can add and delete badges), also unsued disapeared at the same time.
hey @Aimtjie, I just deleted lovelace file from storage and rebooted as indicated here:
now all correct badges and unsued appeared again.
