Blauberg ventilator with S25 controller and WiFi
I am trying to integrate in my HA system a Blauberg ventilator (KOMFORT EC SB 350 S21) with an S25 controller.
The system has a Wifi interface and it is already integrated in my LAN.
The configuration through the Blauberg app is working well.
I have found the following integration (GitHub - jvitkauskas/homeassistant_blauberg_s21: Blauberg S21 integration for Home Assistant) which uses the S21 interface to connect to the unit and I can get it connected (see image below), but the information available is very few and also the commands.
For example, it is not possible to switch on/off the program mode, therefore if this is on, the fan speed cannot be set up.
Has anyone used this integration? Any possibility to improve it?
Are there eventually other working integrations that can have a better access to the ventilator unit?
Thank you.
Hi, what was the host and port you used? How can I define that?
Hi. I have run the configuration in the setup and selected the unit that was visible in the screen. The port was the standard one. The unit has to be already active and visible in the network, then HA will find it.
