I am trying to get some BLE Beacons/Sensors to work in HomeAssistant but I am having some troubles with the MQTT JSON file the Gateway broadcasts. It’s not one topic per sensor but one JSON file containing an array including all the various sensors and beacons.
hardware:
- a Minew G1 Gateway
- various Minew S1 Humidity and Temperature sensors
attached is part of the MQTT JSON files the gateway broadcasts every xx seconds
Objective: I would like to create sensors for each parameter of each device. The only way to distinguish the devices is via their MAC addresses. I know for example that the MAC address “AC233FA29263” is the device in my living room. I would like to log/record the Temperature and Humidity as well as the rssi and battery levels (to create automations that will alert me when the devices are offline or the battery level drops below a certain level)
MQTT JSON output:
[ { "timestamp": "2020-03-29T16:58:11.341Z", "type": "Gateway", "mac": "AC233FC064F3", "gatewayFree": 87, "gatewayLoad": 1.17 }, { "timestamp": "2020-03-29T16:58:11.341Z", "type": "iBeacon", "mac": "AC233FA29261", "bleName": "", "ibeaconUuid": "E2C56DB5DFFB48D2B060D0F5A71096E0", "ibeaconMajor": 0, "ibeaconMinor": 0, "rssi": -51, "ibeaconTxPower": -59, "battery": 0 }, { "timestamp": "2020-03-29T16:58:11.525Z", "type": "S1", "mac": "AC233FA29261", "bleName": "", "rssi": -64, "battery": 100, "temperature": 20.24, "humidity": 57.34 }, { "timestamp": "2020-03-29T16:58:11.530Z", "type": "iBeacon", "mac": "AC233FA29263", "bleName": "", "ibeaconUuid": "E2C56DB5DFFB48D2B060D0F5A71096E0", "ibeaconMajor": 0, "ibeaconMinor": 0, "rssi": -71, "ibeaconTxPower": -59, "battery": 0 }, { "timestamp": "2020-03-29T16:58:11.550Z", "type": "S1", "mac": "AC233FA293DC", "bleName": "", "rssi": -66, "battery": 100, "temperature": 17.93, "humidity": 51.44 }, { "timestamp": "2020-03-29T16:58:11.830Z", "type": "S1", "mac": "AC233FA29262", "bleName": "", "rssi": -68, "battery": 100, "temperature": 18.44, "humidity": 52.76 },
