I have the BLE tracker set up and it’s still not detecting my phones as home. It detected my two phones at least once or they wouldn’t be in the known_devices.yaml. I have about a hundred of these lines in my log, so I know it’s at least sort of working:
2019-11-09 22:38:08 DEBUG (SyncWorker_14) [homeassistant.components.bluetooth_le_tracker.device_tracker] Adding BLE_58:CB:52:12:2C:A9 to BLE tracker
2019-11-09 22:38:08 DEBUG (SyncWorker_14) [homeassistant.components.bluetooth_le_tracker.device_tracker] Adding BLE_8C:8E:F2:D8:7D:E8 to BLE tracker
2019-11-09 22:38:08 DEBUG (SyncWorker_14) [homeassistant.components.bluetooth_le_tracker.device_tracker] Adding BLE_59:99:99:0B:5F:E3 to BLE do not track
2019-11-09 22:38:08 DEBUG (SyncWorker_14) [homeassistant.components.bluetooth_le_tracker.device_tracker] Adding BLE_F9:0E:94:4D:42:AE to BLE do not track
Yes I’m sure BT is on 24/7 on my devices (one Android, one iPhone). Wifi tracking is working great for the Android device; flawlessly actually. It’s awful with the iPhone which is why I’m even bothering with BTLE. What am I missing?
Did you ever get this working? I’m trying to set it up and there doesn’t seem to be a clear documentation on how to get it working on HassIO. On my side, I can’t even get it to discover my devices (get the “No Bluetooth LE devices to track!” error and when I add them manually to known_devices that error is gone but then it just sets the state to “not_home”.
Are you sure your phone uses Bluetooth LE? Bluetooth LE is usually for small battery powered things. Phones usually just use Bluetooth not Bluetooth LE - they are both entirely different. Your phone should most likely be using the standard Bluetooth tracker in home assistant.
I’m having the same problem tracking my Tile devices and fitness trackers using BLE. It works fine for Bluetooth on our phones, but BLE dies after a while.
I’ve tried normal today, but the system almost crashed (it was almost 90% offline after restart) and I could hardly access it again to deactivate this option
Hi all,
in my experience I was able to use both the trackers, normal and le: smartphones are tracked
using [ platform: bluetooth_tracker ] and smartwatches using the le version. In my case was
anyway hard to let them work together probably because of my hardware configuration, I have a
Raspbee shield for the Rpi 3b+ that use the serial port normally used by bluetooth
(/dev/ttyAMA0), so some change needed in configuration at boot and sometime I saw they were
interfering each other and from time to time needed a reset of bluetooth to start over. So now I
turned off the LE tracker and things are more stable for me. If I’ll find a more accurate
configuration maybe I’ll turn it on again, have the watch to be tracked together with the phone
sometime is better and more accurate.
