In the case of integrating HomeAssistant with BleBox Device, we have to add the device to the HA one by one.
Add DleBox Device Integration.
Enter the device’s IP.
Save BleBox device with previously given IP in HA.
We must perform the above steps for each BleBox device. You have 10 devices - you go through the process 10 times. You have 100 BleBox devices - you do 100 integrations and it’s ready.
After all, you can do better. Hey, competition with letter “D” integrates all BleBox devices in one step. I hope that my favorite automation system will also be able to do so.
edigorn
October 23, 2022, 11:23am
2
This topic is related to the following (adding BleBox devices):
This proposal is also related to the possibility of adding BleBox devices. Currently, we have to add devices one by one. It will be nice to see the possibility of adding BleBox devices in one integration step. In the system with the letter “D”, such a possibility exists. BleBox devices are added by entering the device’s IP:
Thank you very much, it looks like the topic has been resolved in Home Assistant 2023.1.
home-assistant:dev
← riokuu:mdns_bbx
opened 12:54PM - 12 Dec 22 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
Devices are proagating info over mDNS.
PR introduces zeroconf/mDNS as a integration ConfigFlow.
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [x] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] The code has been formatted using Black (`black --fast homeassistant tests`)
- [x] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
