Blebox - SABAJ TV K-SMRT-4 - WIFI RJ-45
Please add support for rotate. I added my SABAJ TV K-SMRT-4 - WIFI RJ-45 for my TV easily. It only shows to buttons (move from the wall and back) but my TV lift has also a rotate option (in the iOS app it shows those controls). Thanks in advance.
HI Joost,
You would have better luck if you went to the HA Docs BleBox devices - Home Assistant an looked at the git repo listed there, then put in an issue with them directly. The code Owners may not see it here as quickly.
