Hey folks, subject pretty much says it all but I’ll give more details below.
I’m blind, and want to replace a 10±year-old cheap non-smart Onkyo home theater system. Good audio that I can tune and tweak is very important to me. Unfortunately, this old receiver has a pile of buttons and an inaccessible screen. I’ve done a couple things with an IR blaster but at the end of the day, trying to get what I want from this system is fitting a square peg into a round hole.
I don’t need a full audio ecosystem that follows me from room to room, though I certainly wouldn’t mind one if I could build it with HA automations somehow. All I really want is a 5.1 system with an optional built-in web interface of some sort, and great HA integration. I’m only looking to hook a TV in via HDMI so I don’t need a complex receiver, unless of course that receiver is running the web interface or similar. Can anyone recommend anything?
Also, I’ve been told by other blind folks that the Sonos ecosystem is pretty accessible. Again, I don’t really need excessive smarts like audio following me from room-to-room, but the feature that tunes audio to the characteristics of whatever room you’re in seems nice. But I prefer to hold onto things, and I’m worried that my Sonos gear will be useless in 5 or so years when software support ends. Is the HA integration good enough to work around not having support from the official app? Obviously I’d need it to set them up, but I’m curious to what extent Sonos gear works independently of the cloud and how well the integration works if you’re not using the app. I don’t expect I’ll continue buying new gear once I have my setup working, so in theory if I want the audio-following feature then the gear I’m using will continue supporting it as long as I hold onto it, and I won’t be continually adding to it and mixing firmware versions.
Thanks for any recommendations.
