Set the end point on the blind itself? Yes
Re-pairing, yeah I tried that as well
Even if I close it and then open it halfway, the down arrow still stays greyed…
Just to add, the controls on the Zigbee2MQTT page work perfectly:
(these ones)
It’s just the ones exposed to Home Assistant which don’t seem to align
I can seem to get them to change, (I just opened via the Zigbee2MQTT dashboard and this forced the Home Assistant dash to understand that it had moved), but then closing via the home assistant dash partway, it didn’t release the up direction…
Edit2: Seems that setting a position that is not 0 or 100 in HA will give both arrows, but hitting down (or up) sets that value to 0 or 100 irrespective of when the blind is stopped…
