Blink - Add sensor for external power
I would to see a sensor that indicates if it’s on Power or Battery, so that way I know I need to go reset the GFI.
I have blink cameras and a couple of them are powered by an outside GFI outlet, when the outlet trips the camera goes to batteries. The batteries run down quick when the power has been turned off, and lithium batteries aren’t cheap.
The attached images show that the App indicates Battery level (Dog Yard) vs. External Power (Pool), so hopefully this is doable.
