Blink integration not working
Hi all,
I just recently installed HA via docker and I tried to use the Blink integration but cannot get it to work. After successful login the integration keeps retrying but failing with the following status:
### Needs attention
* blink
Failed setup, will retry: None
The log shows the following entries:
Logger: blinkpy.auth
Source: components/blink/coordinator.py:51
First occurred: March 3, 2026 at 11:29:25 PM (52 occurrences)
Last logged: 9:14:11 PM
Connection error. Endpoint https://rest-prod.immedia-semi.com/api/v1/users/tier_info possibly down or throttled. Error:
Failed to get tier info: 'NoneType' object is not subscriptable
Logger: blinkpy.blinkpy
Unable to extract region is from response None
Cannot setup Blink platform.
Logger: homeassistant.components.blink.coordinator
Source: helpers/update_coordinator.py:354
integration: Blink (documentation, issues)
First occurred: March 3, 2026 at 11:29:25 PM (26 occurrences)
Unexpected error fetching blink data
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 354, in __wrap_async_setup
    await self._async_setup()
  File "/usr/src/homeassistant/homeassistant/components/blink/coordinator.py", line 60, in _async_setup
    raise ConfigEntryNotReady
homeassistant.exceptions.ConfigEntryNotReady: None
Any ideas?
I’m having the exact same issue. I just wanted to reply here to watch if anyone else is and if there is a resolution.
I deleted everything and tried to reinstall the integration and I"m getting invalid auth… is this thing going to get fixed??? It’s no longer connecting
Take a look here
From the frequent changes that Blink is making to their MFA authentication and breaking HA integration, reminds me of the scenario with MyQ. They also kept changing their authentication till they completely removed access to HA. Blink is on the same path it would seem.
As of HA 8.2 the Blink Integration is now working again!!
