Fix is in https://github.com/home-assistant/core/pull/37755
Well… “in”. Still needs to be merged and added to HA.
Manually making the change worked for me.
That’s awesome to see that a fix has already been identified - thanks for that.
Do you know when this would be merged into HA or whether it’s best to perform the change manually in the meantime?
Thanks!
It’s slated for the 0.112.5 bugfix release. Not sure when that’ll be in but I imagine within the next couple days
Same problem here. Thanks fronzbot for your work!
+1 for the whole thread, I changed the 3 files to up the version of blinkpy as described in the github link above and it now works again.
For those of you on docker who want to fix it, log on your docker container with
docker exec -it <name of your HA container> /bin/bash
then cd to /usr/src/homeassistant/ and change the requirements_all.txt and requirements_test_all.txt files so that the line for blinkpy==0.15.1 instead of 0.15.0
next go to /usr/src/homeassistant/homeassistant/components/blink and change manifest.json to the same version
"requirements": ["blinkpy==0.15.1"],
exit and restart your container and it works!
Thanks a lot @fronzbot for the great work!
Worked like a charm. Thanks @dels78. And thanks @fronzbot for all the great work on this integration!
[NEVER MIND! My error was during authentication – I didn’t even make it to the other end-point calls. Turns out it was a remote certificate error, so I ignore all cert errors in C# via:
ServicePointManager.SecurityProtocol = SecurityProtocolType.Tls12 | SecurityProtocolType.Tls11 | SecurityProtocolType.Tls;
ServicePointManager.ServerCertificateValidationCallback += (sender, cert, chain, sslPolicyErrors) => true;
and that fixed the issue. I do not have an issue with the “Host” header on subsequent requests because I never had it there in the first place. Whatever changes they made last Friday seem to have messed with multiple aspects of the integration, and python connections must not have a problem with the certificate issue.]
@fronzbot, Excellent. I am not seeing what I need to change, though (I have my integration written in C#). My GitHub skills are weak and I am not seeing an easy way to find out what you recently changed. Can you summarize, or point me to the files I need to diff and see what I need to change in my code? I am referring to the blinkpy project…
THANK YOU!
sutekh137
I have made these manual updates and was able to get re-connected (thanks @fronzbot @dels78).
Is anyone else having issues with the actual sensor/entity updates? I am seeing lots of these types of errors in the logs. I am also now unable to toggle motion (per camera).
2020-07-14 09:24:55 ERROR (MainThread) [homeassistant.helpers.entity] Update for binary_sensor.blink_XXXX_XXXXX_motion_detected fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 272, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 466, in async_device_update
self.update # type: ignore
File "/usr/src/homeassistant/homeassistant/components/blink/binary_sensor.py", line 59, in update
self.data.refresh()
File "/usr/local/lib/python3.7/site-packages/blinkpy/helpers/util.py", line 203, in wrapper
result = method(*args, *kwargs)
File "/usr/local/lib/python3.7/site-packages/blinkpy/blinkpy.py", line 242, in refresh
sync_module.refresh(force_cache=force_cache)
File "/usr/local/lib/python3.7/site-packages/blinkpy/sync_module.py", line 159, in refresh
self.get_network_info()
File "/usr/local/lib/python3.7/site-packages/blinkpy/sync_module.py", line 148, in get_network_info
self.network_info = api.request_network_status(self.blink, self.network_id)
File "/usr/local/lib/python3.7/site-packages/blinkpy/api.py", line 93, in request_network_status
return http_get(blink, url)
File "/usr/local/lib/python3.7/site-packages/blinkpy/api.py", line 301, in http_get
is_retry=is_retry,
File "/usr/local/lib/python3.7/site-packages/blinkpy/helpers/util.py", line 104, in http_req
if json_resp and "code" in response.json():
File "/usr/local/lib/python3.7/site-packages/requests/models.py", line 898, in json
return complexjson.loads(self.text, **kwargs)
File "/usr/local/lib/python3.7/site-packages/simplejson/__init__.py", line 525, in loads
return _default_decoder.decode(s)
File "/usr/local/lib/python3.7/site-packages/simplejson/decoder.py", line 370, in decode
obj, end = self.raw_decode(s)
File "/usr/local/lib/python3.7/site-packages/simplejson/decoder.py", line 400, in raw_decode
return self.scan_once(s, idx=_w(s, idx).end())
simplejson.errors.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
2020-07-14 09:29:34 ERROR (MainThread) [homeassistant.helpers.entity] Update for binary_sensor.blink_XXXX_XXXXX_camera_armed fails
self.data.refresh()
is_retry=is_retry,
2020-07-14 09:32:49 ERROR (MainThread) [homeassistant.components.script] blink_driveway_motion_on: Error executing script. Unexpected error for call_service at pos 1: Expecting value: line 1 column 1 (char 0)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 153, in _async_step
self, f"_async_{cv.determine_script_action(self._action)}_step"
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 656, in _async_call_service_step
*self._prep_call_service_step(), blocking=True, context=self._context
File "/usr/src/homeassistant/homeassistant/core.py", line 1260, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1295, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 209, in handle_service
self._platforms.values(), func, call, required_features
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 454, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 595, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 485, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 437, in async_enable_motion_detection
await self.hass.async_add_executor_job(self.enable_motion_detection)
File "/usr/src/homeassistant/homeassistant/components/blink/camera.py", line 69, in enable_motion_detection
self._camera.set_motion_detect(True)
File "/usr/local/lib/python3.7/site-packages/blinkpy/camera.py", line 88, in set_motion_detect
self.sync.blink, self.network_id, self.camera_id
File "/usr/local/lib/python3.7/site-packages/blinkpy/api.py", line 265, in request_motion_detection_enable
return http_post(blink, url)
File "/usr/local/lib/python3.7/site-packages/blinkpy/api.py", line 316, in http_post
blink, url=url, headers=blink.auth_header, reqtype="post", is_retry=is_retry
2020-07-14 09:32:49 ERROR (MainThread) [homeassistant.components.automation] Blink Driveway Motion On/Off: Error executing script. Unexpected error for call_service at pos 1: Expecting value: line 1 column 1 (char 0)
task.result()
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 204, in service_handler
await script.async_turn_on(variables=service.data, context=service.context)
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 280, in async_turn_on
await self.script.async_run(kwargs.get(ATTR_VARIABLES), context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 831, in async_run
await run.async_run()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 555, in async_run
await self._async_run()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 572, in _async_run
await self._async_step(log_exceptions=not propagate_exceptions)
task.result()
await coro
await result
Keen to get my blink working again. I see there has been a release today, but the https://version.home-assistant.io/stable.json file is still pointing to the 0.112.4 release. Expect an update on this soon?
To tag onto my previous post, every time I do a HA restart, my entire Blink integration gets nullified. All of the entities. I have to then delete the integration, restart HA agin, and then add it back.
Anyone else experiencing this?
I have been waiting for 0.112.5 to show up in the supervisor. It was released 17 hrs ago. Tried a manual update but no joy.
Same here! I don’t know if minor releases like 0.112.5 show up in the Supervisor. Maybe we’ll have to wait for 0.113
The issue kicked in for me this morning after a reboot. Implemented the fix and all is working perfectly again. Thanks @fronzbot
Did this get added to the 0.113.0b0 beta that is released now? I missed it if its in the notes.
Hi I’m new here and was just wondering if this was still working? I am on Home Assistant version 0.113.0b3 with docker container on UnRaid server (all files reflect the blinkpy==0.15.1 changes.) I get passed the login username/password however the 2FA is never emailed to me. I tried to read through everything but can’t get it to work, sorry if the fix was already mentioned.
