I’m having an issue with my new Blink cameras. I got them a week ago and set them up in Home Assistant without issue. I was able to arm/disarm the system. However, yesterday it stopped working. I tried to uninstall/reinstall the Blink integration but it didn’t work. I did verify through IFTTT that I could connect to my Blink account. Any help would be greatly appreciated. Below are the logs I’m getting.
After trying to reboot HA, I have this in my logs:
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 220, in async_setup
hass, self
File "/usr/src/homeassistant/homeassistant/components/blink/__init__.py", line 98, in async_setup_entry
_blink_startup_wrapper, entry
File "/usr/src/homeassistant/homeassistant/components/blink/__init__.py", line 66, in _blink_startup_wrapper
blink.setup_params(entry.data["login_response"])
File "/usr/local/lib/python3.7/site-packages/blinkpy/blinkpy.py", line 189, in setup_params
self.networks = self.get_networks()
File "/usr/local/lib/python3.7/site-packages/blinkpy/blinkpy.py", line 195, in get_networks
response = api.request_networks(self)
File "/usr/local/lib/python3.7/site-packages/blinkpy/api.py", line 82, in request_networks
return http_get(blink, url)
File "/usr/local/lib/python3.7/site-packages/blinkpy/api.py", line 301, in http_get
is_retry=is_retry,
File "/usr/local/lib/python3.7/site-packages/blinkpy/helpers/util.py", line 104, in http_req
if json_resp and "code" in response.json():
File "/usr/local/lib/python3.7/site-packages/requests/models.py", line 898, in json
return complexjson.loads(self.text, **kwargs)
File "/usr/local/lib/python3.7/site-packages/simplejson/__init__.py", line 525, in loads
return _default_decoder.decode(s)
File "/usr/local/lib/python3.7/site-packages/simplejson/decoder.py", line 370, in decode
obj, end = self.raw_decode(s)
File "/usr/local/lib/python3.7/site-packages/simplejson/decoder.py", line 400, in raw_decode
return self.scan_once(s, idx=_w(s, idx).end())
simplejson.errors.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
I uninstalled the integration and tried to reinstall it. However when I enter my credentials I get an “Unexpected Error” and can’t login. In the log I get this:
File "/usr/src/homeassistant/homeassistant/components/blink/config_flow.py", line 75, in async_step_user
response = await validate_input(self.hass, self.blink)
File "/usr/src/homeassistant/homeassistant/components/blink/config_flow.py", line 23, in validate_input
response = await hass.async_add_executor_job(blink.get_auth_token)
File "/usr/local/lib/python3.7/site-packages/blinkpy/blinkpy.py", line 176, in get_auth_token
self.setup_params(self.login_response)
is_retry=is_retry,
