My Blink integration stopped working all of a sudden. Trying to set it up again ends with an unexpected error after entering the verification PIN. This is what I do: I enter my credentials and receive the Blink mail afterwards. Entering the PIN just aborts the procedure with an error. This is what the log says:
Logger: homeassistant.components.blink.config_flow
Source: components/blink/config_flow.py:41
Integration: Blink (documentation, issues)
First occurred: 22:39:09 (1 occurrences)
Last logged: 22:39:09
Unexpected exception
File "/usr/src/homeassistant/homeassistant/components/blink/config_flow.py", line 101, in async_step_2fa
valid_token = await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/blink/config_flow.py", line 41, in _send_blink_2fa_pin
return auth.send_auth_key(blink, pin)
File "/usr/local/lib/python3.8/site-packages/blinkpy/auth.py", line 236, in send_auth_key
json_resp = response.json()
AttributeError: 'NoneType' object has no attribute 'json'
Logger: blinkpy.auth
Source: /usr/local/lib/python3.8/site-packages/blinkpy/auth.py:195
Connection error. Endpoint https://rest-e001.immedia-semi.com/api/v4/account/xxxxx/client/xxxxxx/pin/verify possibly down or throttled.
I experienced similar issues from time to time in the past but setting up a fresh integration usually fixed it. But not this time.
I noticed that the integration didn’t work anymore after I moved my arm/disarm automations to node-red. While doing this I paid attention not to flood Blink’s servers with too many arm/disarm requests. Don’t know if this caused a blocking of my account? The Blink app is still working and I can control my cameras from it.
I’m pretty clueless right now and any help is much appreciated…
Home Assistant Version: core-2021 3.3, supervised on Debian
UPDATE:
I just forced a WAN IP refresh from my ISP by restarting my router and tried again to setup the Blink integration. This time I did not receive a mail from Blink with the authorization PIN and I just proceeded without it and it succeeded.
So all sensors and services are available now but the preview images are not loading. I have an automation for refreshing the preview images once an hour which is now working again as I can see it in the Blink app.
Home Assistant now generates every 5 seconds this log entry:
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 129, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 496, in get
return await self.handle(request, camera)
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 513, in handle
image = await camera.async_camera_image()
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 382, in async_camera_image
return await self.hass.async_add_executor_job(self.camera_image)
File "/usr/src/homeassistant/homeassistant/components/blink/camera.py", line 92, in camera_image
return self._camera.image_from_cache.content
AttributeError: 'NoneType' object has no attribute 'content'
