BlitzHome BH-AP1 Air Purifier Tasmota autodiscovery
Blueprint to create an automation which generates MQTT discovery payloads for BlitzHome BH-AP1 air purifier running Tasmota.
This way of integrating allows customization of entities to the specificities of the device.
Requires configuring rules in Tasmota descibed on blakadder.com. The article also explains some choices in the entity configurations.
blueprint:
  name: "Tasmota Discovery: BlitzHome Air Purifier BH-AP1"
  source_url: 'https://github.com/tasmota/blueprints/blob/main/discovery_blitzhome_bh-ap1.yaml'
  description: |
    Set up a BlitzHome BH-AP1 air purifier running Tasmota in Home Assistant. See device template page for additional information: [BlitzHome BH-AP1 Air Purifier](https://templates.blakadder.com/blitzhome_BH-AP1.html).
    **Requires rules configured in Tasmota!**
    <details>
        rule3
        on tuyareceived#dptype1id1 do publish2 %topic%/powerstate %value% endon
        on tuyareceived#dptype4id3 do publish %topic%/mode %value% endon
        on tuyareceived#dptype2id2 do publish %topic%/pm25 %value% endon
        on tuyareceived#dptype2id5 do publish %topic%/filterlife %value% endon
        on tuyareceived#dptype4id19 do publish %topic%/countdown %value% endon
        on tuyareceived#dptype4id22 do publish %topic%/airquality %value% endon
        on event#sleep do tuyasend4 3,0 endon
        on event#auto do tuyasend4 3,1 endon
        on event#manual do tuyasend4 3,2 endon
        on tuyareceived#dptype4id4 do backlog var1 %value%; add1 1; event sendfanspeed endon
        on tuyareceived#dptype1id1=0 do publish %topic%/fanspeed 0 endon
        on event#sendfanspeed do publish %topic%/fanspeed %var1% endon
    </details>
    Blog post explaining this blueprint on [blakadder.com](https://blakadder.com/bh-ap1-in-home-assistant/).
    <small>Built for Home Assistant 2022.8</small>
  domain: automation
  input:
    tasmota_device:
      description: "Select the Tasmota device"
      selector:
        device:
          integration: tasmota
          manufacturer: "Tasmota"
    topic:
      name: Tasmota MQTT Topic
      description: |
          Found in the web UI "Information" menu under "MQTT Topic" or with `Topic` command
      selector:
        text:
mode: single
max_exceeded: silent
variables:
  device_id: !input tasmota_device
  topic: !input topic
  connections: "{{ device_attr(device_id, 'connections') }}"
  name: "{{ device_attr(device_id, 'name') if device_attr(device_id, 'name_by_user') == None else device_attr(device_id, 'name_by_user') }}"
  macaddr: >-
    {%- for i in device_attr(device_id, 'connections') -%}
      {{ i[1].replace(":", "") }}
    {% endfor %}
  payload_fan: >-
        "name":"' ~ name ~ '",
        "icon":"hass:air-purifier",
        "state_topic":"' ~ topic ~ '/powerstate",
        "state_value_template":"{{ value | int }}",
        "command_topic":"cmnd/' ~ topic ~ '/TuyaSend1",
        "command_template":"1,{{ value }}",
        "payload_on":"1",
        "payload_off":"0",
        "percentage_state_topic":"' ~ topic ~ '/fanspeed",
        "percentage_value_template":"{{ value | int }}",
        "percentage_command_topic":"cmnd/' ~ topic ~'/Backlog0",
        "percentage_command_template":"{% if value == 0 %}tuyasend 1,0{% else %}tuyasend4 4,{{ value - 1 }}{% endif %}",
        "preset_modes":["Sleep","Auto","Manual"],
        "preset_mode_state_topic":"' ~ topic ~ '/mode",
        "preset_mode_value_template":"{%- set val = { \'0\':\'Sleep\', \'1\':\'Auto\', \'2\':\'Manual\' } -%}{{ val[value] | default(\'\', true) }}",
        "speed_range_max":2,
        "preset_mode_command_topic":"cmnd/' ~ topic ~ '/event",
        "avty_t":"tele/' ~ topic ~ '/LWT",
        "pl_avail":"Online",
        "pl_not_avail":"Offline",
        "uniq_id":"' ~ macaddr ~ '_fan",
        "dev":{"cns":[["mac","' ~ macaddr ~ '"]]}
  payload_pm25: >-
        "name":"' ~ name ~ ' PM2.5",
        "state_topic":"' ~ topic ~ '/pm25",
        "device_class":"pm25",
        "unit_of_measurement":"µg/m³",
  payload_filterlife: >-
        "name":"' ~ name ~ ' Filter Life",
        "state_topic":"' ~ topic ~ '/filterlife",
        "icon":"mdi:ticket-percent-outline",
        "unit_of_measurement":"%",
        "entity_category":"diagnostic",
        "uniq_id":"' ~ macaddr ~ '_filterlife",
  payload_airquality: >-
        "name":"' ~ name ~ ' Air Quality",
        "icon":"mdi:thought-bubble",
        "state_topic":"' ~ topic ~ '/airquality",
        "value_template":"{%- set val = { \'0\':\'Excellent\', \'1\':\'Good\', \'2\':\'Poor\' } -%}{{ val[value] | default(\'\', true) }}",
        "uniq_id":"' ~ macaddr ~ '_airquality",
  payload_filterreset: >-
        "name":"' ~ name ~ ' Filter Reset",
        "icon":"mdi:image-filter-tilt-shift",
        "command_topic":"cmnd/' ~ topic ~ '/tuyasend1",
        "payload_press":"11,1",
        "entity_category":"config",
        "uniq_id":"' ~ macaddr ~ '_filterreset",
  payload_countdown: >-
        "name":"' ~ name ~ ' Countdown",
        "state_topic":"' ~ topic ~ '/countdown",
        "icon":"hass:timer-sand",
        "options":["Off","1h","2h","4h","8h"],
        "value_template":"{%- set val = { \'0\':\'Off\', \'1\':\'1h\', \'2\':\'2h\', \'3\':\'4h\', \'4\':\'8h\' } -%}{{ val[value] | default(\'Off\', true) }}",
        "command_topic":"cmnd/' ~ topic ~ '/tuyasend",
        "command_template":"{%- set val = { \'Off\':\'0\', \'1h\':\'1\', \'2h\':\'2\', \'4h\':\'3\', \'8h\':\'4\' } -%}19,{{ val[value] | default(\'\', true) }}",
        "uniq_id":"' ~ macaddr ~ '_countdown",
trigger_variables:
  topic: !input topic
  - platform: homeassistant
    event: start
  - platform: mqtt
    topic: '{{ "tele/" ~ topic ~ "/LWT" }}'
    payload: "Online"
  - service: mqtt.publish
      topic: "homeassistant/fan/{{ macaddr }}/airpurifier/config"
      retain: true
      payload: "{{ payload_fan }}"
      topic: "homeassistant/sensor/{{ macaddr }}/pm25/config"
      retain: true
      payload: "{{ payload_pm25 }}"
      topic: "homeassistant/sensor/{{ macaddr }}/filterlife/config"
      retain: true
      payload: "{{ payload_filterlife }}"
      topic: "homeassistant/sensor/{{ macaddr }}/airquality/config"
      retain: true
      payload: "{{ payload_airquality }}"
      topic: "homeassistant/button/{{ macaddr }}/filterreset/config"
      retain: true
      payload: "{{ payload_filterreset }}"
      topic: "homeassistant/select/{{ macaddr }}/countdown/config"
      retain: true
      payload: "{{ payload_countdown }}"
  - delay:
      hours: 0
      minutes: 0
      seconds: 5
      milliseconds: 0
      topic: "cmnd/{{ topic }}/tuyasend8"
      payload: ""
Please check the source_url if there are updates to the template
