BlitzWolf BW-SHP13 not showing power consumption
Newbie alert
Hi.
Somewhat new to HA, so bare with me - might be a simple fix :slight_smile:
i bought a set of BlitzWolf® BW-SHP13 Zigbee plugs, connected via Conbee II.
The devices should be able to view power consumptions ect, but in HA i only get on/off entiti. Anyone else using these and know what to do?
In Deconz, i can see the power consumptions by number.
Check the Blitzwolf Plug in the Deconz devices list on the Integration page (http://:8123/config/integrations) - for me the plug device contains a switch entity and 2 sensors - one for power and one for overall consumption
It only shows one.
I bought two of them
One of them is precented as Vendor: “_TZ3000_g5xawfcq” Model: TS0121
The other one is precented as Haiman / TS0121
Does not seem to show any sensors.
Little “same” problem.
I’ve the same plug and with HA it’s show me 3 entity but overall consumption stay in unknown (I use for a week and no change).
The power entity work well!
I use ZHA integration module in HA.
Someone have an idea ? Thanks in advance :slight_smile:
2021-01-26 11_53_28-Window
I had the same problem, so a while ago I opened an Issue in zha-device-handlers github.
It looks like the problem is due to a limitation in ZHA: It’s only possible to create 1 sensor for each zigbee cluster.
Thanks for your answer … this limitation it’s only for plug like this one ?
Because I’ve other sensor like temperature sensor who show me multiple sensor like this one =>
2021-01-26 13_25_27-Window
It works with Zigbee2MQTT
Im not an expert at all, but I think that the temperature sensor can have multiple entities because each one has its own zigbee cluster: Humidity / Pressure / Temperature / Power.
However on the smartplug, both energy consumption (kWh) and power (W) share the same zigbee cluster: ElectricalMeasurement.
My understanding is that right now ZHA only allows one entity on each cluster. You could also try with Zigbee2MQTT to see if that works better in this case.
I am also with ZHA and can confirm the same. Is it possible for the ZHA integration to add this capability in the near future? Or is it a limitation by design?
hello, any update about this issue in ZHA?
I tried to show power consumption using the template integration:
  - platform: integration
    source: sensor.blitzwolf5_tv_power
    unit_prefix: k
    round: 2
but it show me the following error:
2021-02-13 11:43:33 ERROR (MainThread) [homeassistant.components.sensor] Error adding entities for domain sensor with platform integration
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 315, in async_add_entities
await asyncio.gather(*tasks)
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 506, in _async_add_entity
await entity.add_to_platform_finish()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 530, in add_to_platform_finish
await self.async_added_to_hass()
File “/usr/src/homeassistant/homeassistant/components/integration/sensor.py”, line 125, in async_added_to_hass
self._state = Decimal(state.state)
decimal.InvalidOperation: [<class ‘decimal.ConversionSyntax’>]
I havent got this working yet no. But i am using Conbee/Decons, not zha.
No, wait and see if ZHA devs comment more in [Device Support Request] BlitzWolf BW-SHP13 smart plug (aka Tuya TS0121) · Issue #605 · zigpy/zha-device-handlers · GitHub
ok great, I’ll take a look also to the issue you posted, thanks!
I’m using phoscon/deconz and have the same problem. I had a bunch of this sockets working fine but this specific one only shows Switch on/off.
Same issue here. Latest version of deconz and HA. I deleted the device via the deconz REST API and tried to pair again, but it keeps coming back with only on/off. Very strange because it’s identical to another SHP13 I have that works fine (power & consumption sensors are created). In deconz, both have correct real time metering values.
Everyone with this problem might want to check this thread (it solved my issue):
I fixed 2 of this devices only with switch doing the following:
(Device previously added and online as a light, with some item connected to the socket/plug turned on)
In deconz:
  • Panels, Cluster Info, Basic
  • Reset Factory reset (Exec button)
  • Go to Phoscon, Add SENSOR (not light)
    And it turns green as a discovered sensor.
is there also fix for this issue while using ZHA ?
same here, actually I am happy using ZHA instead of phoscon so I prefer waiting for a solution in ZHA.
