Blitzwolf shp14 outdoor 2 relay strip ESP-Home yaml
I couldn’t find any yaml for flashing this device here so I figured I could share it in case anyone else want’s it.
BlitzWolf® BW-SHP14 WiFi Outdoor Socket 3680W EU/1760W US 16A with Dual Outlets, APP Control, Voice Control, IP44 Waterproof and Timer & Schedule
It will expose the two relays, a RSSI sensor and a restart switch to Home Assistant, the LEDs and button are set to internal.
Single click on the button toggles relay 1 and long press toggles relay 2.
esphome:
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "6c9f36bbb631cdc080f6d8abc420a19e"
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    #static_ip: 192.168.1.193
    #gateway: 10.0.0.1
    #subnet: 255.255.255.0
  ap:
    ssid: "Blitzwolf Fallback Hotspot"
    password: "5xwTWv3w7MmI"
captive_portal:
binary_sensor:
  - platform: gpio
    pin: 3
    internal: true
    filters:
      - invert:
    on_click:
    - min_length: 10ms
      max_length: 500ms
      then:
        - switch.toggle: relay_1
    - min_length: 500ms
      max_length: 2000ms
      then:
        - switch.toggle: relay_2
switch:
  - platform: gpio
    pin: 12
    on_turn_on:
      - switch.turn_on: led2
    on_turn_off:
      - switch.turn_off: led2
  - platform: gpio
    pin: 1
    internal: true
    inverted: true
    name: "Blitzwolf LED 2"
  - platform: gpio
    pin: 14
    on_turn_on:
      - switch.turn_on: led1
    on_turn_off:
      - switch.turn_off: led1
  - platform: gpio
    pin: 5
    internal: true
    inverted: true
    name: "Blitzwolf LED 1"
  - platform: restart
  - platform: wifi_signal
    name: "Blitzwolf WiFi RSSI"
    update_interval: 60s
I don’t have any real use data of it yet as I picked it up from the post office three hours ago, but it seems to work fine in ESP-Home.
Hey there! Thanks for the share.
Did you end up getting this plug to work with HA?
Any hardware/connector you suggest for flashing?
Thanks.
It works great.
I can’t remember the flashing process. I can’t believe it was anything out of the ordinary
