for the particular cross you mentioned something like this would do it, but if you have more flows with different triggers and conditions you should add all those triggers whithin the trigger node and branch the conditions accordingly in order to have everything merged
[{"id":"ce88f047.1ef03","type":"server-state-changed","z":"937ef78.ec6b408","name":"Motion sensor to detect sleep","server":"9405c3fe.d0a6c","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.your_sensor","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[],"x":220,"y":540,"wires":[["45fe7090.2bd11"],[]]},{"id":"45fe7090.2bd11","type":"api-call-service","z":"937ef78.ec6b408","name":"Input boolean on","server":"9405c3fe.d0a6c","version":3,"debugenabled":false,"service_domain":"homeassistant","service":"turn_on","entityId":"input_boolean.nap","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":460,"y":540,"wires":[[]]},{"id":"a090cbb9.22de78","type":"server-state-changed","z":"937ef78.ec6b408","name":"Triggers","server":"9405c3fe.d0a6c","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sun.sun, input_boolean.nap","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[],"x":160,"y":640,"wires":[["a85385bf.3fc478"]]},{"id":"a85385bf.3fc478","type":"api-current-state","z":"937ef78.ec6b408","name":"nap off?","server":"9405c3fe.d0a6c","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.nap","state_type":"str","blockInputOverrides":true,"outputProperties":[],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":320,"y":640,"wires":[["68a32252.034cbc"],["b202b335.afbe3"]]},{"id":"68a32252.034cbc","type":"api-current-state","z":"937ef78.ec6b408","name":"below horizon?","server":"9405c3fe.d0a6c","version":3,"outputs":2,"halt_if":"below_horizon","halt_if_type":"str","halt_if_compare":"is","entity_id":"sun.sun","state_type":"str","blockInputOverrides":false,"outputProperties":[],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":500,"y":620,"wires":[["d9cf5e4e.1da1"],[]]},{"id":"d9cf5e4e.1da1","type":"api-call-service","z":"937ef78.ec6b408","name":"light on","server":"9405c3fe.d0a6c","version":3,"debugenabled":false,"service_domain":"","service":"","entityId":"","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":680,"y":600,"wires":[[]]},{"id":"b202b335.afbe3","type":"api-call-service","z":"937ef78.ec6b408","name":"light off","server":"9405c3fe.d0a6c","version":3,"debugenabled":false,"service_domain":"","service":"","entityId":"","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":480,"y":660,"wires":[[]]},{"id":"9405c3fe.d0a6c","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
