Hi guys,
I was wondering if there is any option to block entities for actions.
Possible use case:
- Having a group of covers being moved if sun automations think they should
- One cover is the door to terrace and should not be moved if door is open
Probably I could go for having each cover in one action with a simple condition asking some sensors that could prevent the moving of this cover. This approach would expect to have all possible blocking conditions in every automation. This feels more like a workaround, since a blocking feature is state of the art in the industrial grade automation bus systems (like knx).
Do I miss something, or is it not possible to create such blocking behavior at this time ?
My approach was to create some kind of python scripts, but before moving on with this I would like you to let me know if there is any better way.
For the records, a python script to add an attribute “blocked” to a group of entities or a entity itself:
entity_id = data.get('entity_id')
if(entity_id.startswith('group')):
for entity_id in hass.states.get(entity_id).attributes['entity_id']:
attributes = hass.states.get(entity_id).attributes.copy()
attributes['blocked'] = True
logger.error("Block entity %s" % entity_id)
hass.states.set(entity_id, None, attributes)
else:
and a poc to make some actions based on the attribute blocked:
if hass.states.get(entity_id).attributes.get('blocked'):
logger.error("Entity %s is blocked" % entity_id)
else:
logger.error("Entity %s is not blocked, go on" % entity_id)
else:
logger.error("Entity %s is not blocked" % entity_id)
else:
Regards,
Andreas
