My first blueprint that can fool an ohmigo wifi sensor that it is 20 degrees outside for as many hours as you want per day. When it is not expensive, it syncs with an existing outdoor sensor.
Feel free to try and make suggestions for improvement, keep in mind that it is my first attempt so there are bound to be bugs.
In order for this blueprint to work, the following elements must be met.
- Nordpool integration
- An outdoor sensor that has the actual outdoor temperature
- A sensor that can manipulate the outdoor temperature, for example https://www.ohmigo.io/product-page/ohmigo-ohm-on-wifi or equivalent
“Many thanks to Blacky for all the help with your technical skills.”
