after installing ha 2023.3 i started having ha crash randomly. From the logs I can see this… how can it be solved?
RuntimeError: Event loop is closed
2023-04-08 01:19:07.289 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_51] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self._bootstrap_inner()
File “/usr/local/lib/python3.10/threading.py”, line 1016, in _bootstrap_inner
self.run()
File “/usr/local/lib/python3.10/threading.py”, line 953, in run
self._target(*self._args, **self._kwargs)
File “/usr/local/lib/python3.10/concurrent/futures/thread.py”, line 81, in _worker
work_item = work_queue.get(block=True)
2023-04-08 01:19:07.293 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_22] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.317 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_56] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.320 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_50] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.353 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_18] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.357 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_60] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.386 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_46] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.387 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_8] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.419 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_25] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.427 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_30] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.447 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_43] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.455 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_10] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.473 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_39] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.485 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_22] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.502 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_20] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.514 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_50] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.530 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_7] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.545 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_60] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.558 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_40] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.572 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_46] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.583 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_11] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.603 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_25] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.610 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_16] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.635 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_43] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.641 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_2] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.663 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_39] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.670 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_45] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.696 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_20] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.698 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_48] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.730 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_7] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.738 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_9] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.759 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_40] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.765 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_33] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.790 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_11] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.797 WARNING (Thread-1639 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_17] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.820 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_16] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.849 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_2] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.880 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_45] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.913 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_48] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.944 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_9] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:07.977 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_33] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
2023-04-08 01:19:08.006 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_17] is still running at shutdown: File “/usr/local/lib/python3.10/threading.py”, line 973, in _bootstrap
self.run()
