I have a question.
I would like to block certain clients based on Unifi Integration after 60 minutes connectivity. This is the code I have so far:
alias: Disconnect clients after 1 hour
description: Automatically disconnect clients after 1 hour of being online
triggers:
- entity_id:
- device_tracker.unifi_default_f4
- device_tracker.unifi_default_04
to: home
for: "01:00:00"
trigger: state
conditions:
- condition: state
entity_id: input_boolean.clients_reset
state: "off"
actions:
- data:
entity_id: device_tracker.unifi_default_f4
action: unifi.block_client
- data:
entity_id: device_tracker.unifi_default_04
- entity_id: input_boolean.clients_reset
action: homeassistant.turn_off
mode: single
Using this results in a error:
The automation "Disconnect clients after 1 hour" (automation.disconnect_clients_after_1_hour) has an unknown action: unifi.block_client.
So the yaml code Unifi.block_client isn’t working.
Checking the unifi services I neither can find “block_client” as a service.
Isn’t this supported?
I also read something about block-sta, but also without succes.
Has any one been successfull on this?
Thanks!
