Blue Iris cam stuck on motion detected
I’m using the Blue Iris NVR integration to get motion detection from my cameras. One of my garage cameras keeps showing motion in HA when there is no motion on the camera and the Blue Iris log doesn’t show that there was motion. I tried reloading the Blue Iris NVR integration and tried manually setting the state of that camera to “off”. In both cases it immediately reverted to “on/detected”.
Has anyone else seen an issue like this or know how I can solve it?
I’m having the same issue with just a single camera.
I’ve unplugged the camera and manually set the motion status to “off”, but after a few seconds it flips back to on…
Were you able to track this down?
I never did find out what fixed it, but it’s not a problem anymore. I’m, not sure what fixed it.
I just started having the exact same issue a few days ago, updated to 11.1 and same issue. Restored back to early October backup and same thing. Updated yesterday to 11.2 and issue remains.
I’m using the PIR sensor built into the camera to detect motion, 3 other identical cameras not having the same issue.
I have found that when I reboot HA motion it works correctly until motion is sensed the first time then it gets stuck in the motion detected state. As above I can manually set state to “off” and it automatically flips to “on” after a few seconds.
