Hi @jcuccia, I published a custom component few months ago for BI, you can check it in the following link:
I moved the repo to GitHub:
Basically it provides you an integration to the BI to all camera, creates binary sensors for each camera for connectivity and motion (via MQTT) and arm / disarm based on profiles without the need to add command line / scripts
Does anyone know if it is possible to trigger a different MQTT message for each different motion zone? e.g., so as to have a binary sensor for the porch, another for the driveway, and so on.
Yes, since you configure each camera’s alerts separately. Using your driveway as an example, have BI send something like this:
When triggered:
MQTT topic: blueiris/driveway/motion
Post/payload: on
Check Alert again when trigger is reset
Post/payload: off
Thanks, but I was looking to configure alerts separately for each unique zone. e.g., single camera, but 7 different alert (MQTT) configs for the 7 different zones. Since my posting I’d read that technically you can achieve this by duplicating your single camera 6 additional times (and hiding them), but it would be nice if a future Blue Iris release enhances the customization ability here. I should be able to change the MQTT payload to match the specific triggering zone involved (or they should at least add a @ZONE type GV that you can pass into the MQTT payload)
I followed your instructions and have all 4 of my cameras setup on a Camera Tab on Lovelace as picture entities. When you click on the Camera tab my PC that runs Blue Iris constantly makes the sound when someone logs in to a camera on BI. The camera images are updating every few seconds. Is it possible to adjust the time between the refreshes to stop this?
Thank you. I couldn’t get the cameras to work using the username & password in the config file so I used the option above that allows only the IP Address of my HA box to log in. The Admin account is being used so I unchecked the “On login play sound” on that account
Is there a way to push a screenshot of the latest triggered camera? For instance I have Hassio in Kiosk mode on my tablet, is there a way to have a screenshot popup automatically when I specific camera is triggered?
Not sure what version of Blue Iris you are runnning, but the help file in mine says you need the /video.mjpg at the end of the url like: http://192.168.1.100:81/mjpg/Cam1/video.mjpg
This works for me, but sadly only when on my home network…the streaming falls waaaaay behind when I switch to my cell connection outside of the house.
Pretty sure that is just my ISP though.
- id: blueiris_profile_2
alias: Blue Iris Profile 2
platform: state
entity_id: binary_sensor.people_home
to: 'off'
- service: switch.turn_on
entity_id: switch.blue_iris
- id: blueiris_profile_1
alias: Blue Iris Profile 1
platform: state
to: 'on'
- service: switch.turn_off
And the command line switch:
switches:
blue_iris:
command_on: '/usr/bin/curl -X GET "http://a.b.c.d:8081/admin?profile=2&lock=2"'
command_off: '/usr/bin/curl -X GET "http://a.b.c.d:8081/admin?profile=1&lock=1"'
friendly_name: Blue Iris
