Has anyone else had this issue. I currently have the blue iris integration set up and everything works very well. I have some lovelace cards to show the cameras and in general things go smoothly. However I have noticed that every couple of days the streams will fall behind. For example I opened home assistant this afternoon and it is showing a stream from 3am yesterday morning. If I restart home assistant then everything returns to normal for a couple of days then it will happen again. It does not seem to be a gradual thing as in the stream slowly gets further and further behind but just seems to get stuck on an old cache. Any ideas?
