Version info -
Core: 2202.6.7
HAOS: 8.2
HACS: 1.25.5
Blue Iris Integration: 1.0.14
Blue Iris NVR: 5.5.9.3
Ever since Ubiquiti updated Unifi Protect and made changes to their camera feeds, I’ve been battling an issue with the camera feeds not displaying in HA. Initially, it’s because they weren’t displaying in BI, so I updated that, and everything seemed fine. Then I updated everything in HA, including core, OS, and all the integrations. Now I’ve been fighting the same symptom of camera feeds not showing up. The logs show this:
Error from stream worker: Stream ended; no additional packets
09:50:23 – (ERROR) Stream - message first occurred at 08:57:09 and shows up 22 times
09:50:22 – (ERROR) Stream - message first occurred at 08:57:09 and shows up 22 times
Failed to connect http://10.1.6.165:81/json, Error: Cannot connect to host 10.1.6.165:81 ssl:False [Connect call failed ('10.1.6.165', 81)], Line: 84
09:50:21 – (ERROR) Blue Iris NVR (custom integration) - message first occurred at 08:58:51 and shows up 52 times
09:50:21 – (ERROR) Stream - message first occurred at 08:57:06 and shows up 23 times
Error when loading first segment 'http://10.1.6.165:81/h264/masterbr/1.ts?session=509d773b372d34d9149469c65aae5a6c'
09:45:52 – (ERROR) components/stream/worker.py - message first occurred at 09:00:02 and shows up 5 times
Is anyone else having this issue? Any ideas how to fix it?
