Blue Print - Entering and Leaving Zone notifications
I am creating a blueprint, that shows when someone enters or leaves a zone. It will send me a notification. I am creating this blueprint from scratch. I have several zones, and was going to lump all this together in one blueprint.
  1. Is it possible to have a different notification everytime they enter or leave a zone, or would multiple blueprints need to be created?
  2. Is it possible to see what zone the person is in, via HA?
there are several existing blueprints that what you are looking for, and some do a lot more. Might want to look at mine… ⚠️ Repeating Alert Notifications w/ Actionable Buttons and other features
As LTek stated there are a number of blueprints that already handle this kind of thing.
Based on what little you have described, it barely seems like something that is worth the effort of creating a blueprint at all… if you can provide the automation you want to base the blueprint off it would make it easier for us to give more specific guidance.
Yes, using templates.
Please clarify the question.
I want to see on a map what zone they are in, in case I forget. Example, they left to go to work. But I did not read the notification, dismiss it with out looking. I want to look up where they are at on a map.
I have several zones: Work, home, church etc… Is there a way to visually see where they are located, on a map?
That blueprint you linked me worked perfectly for what I need thanks.
