I created mine as a sensor instead of a binary_sensor, It works very well so far.
The problem I have now is when I try to create a script to send a mqtt payload message to blue iris.
Blue Iris is listening on this topic (topic: ‘BlueIris/admin’). with capital B and I.
Apparently scripts in HA do not like capitals letters, and blue iris do not receive the payload.
@jaburges I found scripts elsewhere on the forum to et & set BI profiles, and I am able to successfully change the profiles with a combination of HASS shell commands and embedded python scripts.
thanks for sharing - this is right at my limit of ability - i’m just looking to extract the correct URL for sending Curl requests with a shell_command for each - cant quite figure out all the json and extra info
I’m suprised someone smarter than me hasn’t built something using the Smartthings BlueIris integration:
i wish i knew how but would NOT know where to start. i’m assuming the BI connection is fine, it would just need the smartthings API parts changes to HA components.
thank you. and does blueiris pick up the Ring?
and can you install it in Linux? Basically I run a NuC with Ubuntu, so I’d like to put it in the same place.
It’s been awhile since I’ve written anything in this thread, however I just got my Lenovo Google Smart Display and wanted it to be able to do “OK Google, show me the baby room” and have the baby camera display on the screen.
I’m pleased to say I’ve gotten it working, including every other camera hooked upto BlueIris. You can even send the signal to any Chromecast device!!! It’s late at night right now, but if you’re interest to know how to do this let me know and I’ll do a write up.
Yes, definitely interested! I’ve tried feeding my BlueIris streams to chromecast in the past, but after multiple attempts I gave up. Very curious how you got that part working!
I don’t have a Smart Display (yet), but this would be a compelling reason to get one.
