Hey, I’m trying to use the blueprint from ZHA - Aqara Wireless Remote Switch (Double Rocker) for my Aqara Wireless Remote Switch that if I press the left switch it triggers another switch connected to a light.
Issue is that the physical button doesn’t trigger the automation, but if I trigger the automation manually from HA, it works.
I checked the blueprint and studio code gives error on action-s. Can this be the issue? What action should go there?
And if the blueprint is correct, how can I check that the device works with the blueprint?
