germanm
September 15, 2022, 1:06pm
1
I’m struggling with making a modification to an existing blueprint by adding a duration input.
I have a duration input that later on I want to use on a calculation (comparing duration to duration) but I think variables are string.
This works:
remaining > timedelta(minutes=10)
But the approach I’m trying on the snippet below doesn’t work:
remaining > button1_duration
A snippet of the blueprint, containing only the parts I’m having issues with:
blueprint:
input:
button1_duration:
name: Button 1 Duration (Top Left)
default: 0:10:00
selector:
duration:
variables:
button1_duration: !input button1_duration
- choose:
- conditions:
- condition: trigger
sequence:
- choose:
- conditions:
- condition: template
value_template: '{% set remaining = timedelta(seconds=(as_timestamp(state_attr(fan_timer,
''finishes_at'')) - as_timestamp(now())) | int) %}{{ remaining > button1_duration
I hope this makes sense to the most experienced guys here and it’s a simple thing I just can’t figure out.
Thanks!
petro
(Petro)
September 15, 2022, 1:22pm
2
apparently the duration is a dictionary.
variables:
bds: !input button1_duration
button1_duration: >-
{{ timedelta(hours=bds.hours, minutes=bds.minutes, seconds=bds.seconds) }}
- choose:
- conditions:
sequence:
- choose:
- conditions:
value_template: '{% set remaining = state_attr(fan_timer, ''finishes_at'') | as_datetime | as_local - now() %}{{ remaining > button1_duration }}'
Also, I fixed your remaining syntax. You were comparing an int to a timedelta. When you subtract two datetimes, they make a timedelta.
Also, you can optimize what I wrote, but it might not make sense to you.
variables:
{{ timedelta(**bds) }}
germanm
September 15, 2022, 1:56pm
3
Thanks, @petro !
We’re getting closer, but I’m still getting errors in the action:
unsupported type for timedelta minutes component: dict
"Unable to compute proper state for state_UNKNOWN for switch.mbath_fan with scene controller 41fae806b8d154209b024b9314573178."
9:49:47 AM – (ERROR) components/system_log/__init__.py - message first occurred at September 14, 2022 at 3:45:11 PM and shows up 14 times
Error in 'choose[0]' evaluation: In 'template' condition: TypeError: unsupported type for timedelta minutes component: dict
9:49:47 AM – (WARNING) helpers/script.py - message first occurred at September 14, 2022 at 3:45:11 PM and shows up 25 times
Do you see anything wrong in this code?
I’ve adjusted the value_template code to what you sent as it’s cleaner, but it looks like it’s the same error as before:
- choose:
- conditions:
sequence:
- choose:
- conditions:
value_template: '{% set remaining = state_attr(fan_timer, ''finishes_at'') | as_datetime | as_local - now() %}{{ remaining > timedelta(minutes=30) }}'
sequence:
- event: ZEN32_EXHAUST_FAN_BLUEPRINT_STATE_CHANGE
event_data:
scene_controller: !input scene_controller
fan_switch: !input fan_switch
fan_timer: !input fan_timer
new_state: ON_GT_45_MIN
- conditions:
value_template: '{% set remaining = state_attr(fan_timer, ''finishes_at'') | as_datetime | as_local - now() %}{{ remaining > timedelta(minutes=15) and remaining <= timedelta(minutes=30) }}'
sequence:
event_data:
new_state: ON_GT_30_LTE_45_MIN
- conditions:
value_template: '{% set remaining = state_attr(fan_timer, ''finishes_at'') | as_datetime | as_local - now() %}{{ remaining > timedelta(minutes=10) and remaining <= timedelta(minutes=20) }}'
sequence:
event_data:
new_state: ON_GT_20_LTE_30_MIN
- conditions:
value_template: '{% set remaining = state_attr(fan_timer, ''finishes_at'') | as_datetime | as_local - now() %}{{ remaining > button1_duration and remaining <= timedelta(minutes=10) }}'
sequence:
event_data:
new_state: ON_GT_10_LTE_20_MIN
- conditions:
value_template: '{% set remaining = state_attr(fan_timer, ''finishes_at'') | as_datetime | as_local - now() %}{{ remaining <= button1_duration }}'
sequence:
event_data:
new_state: ON_LTE_10_MIN
default:
- service: system_log.write
data_template:
level: error
logger: zen32_exhaust_fan_blueprint
message: '"Unable to compute proper state for {{ trigger.id }} for {{ fan_switch }} with scene controller {{ scene_controller }}."'
germanm
September 15, 2022, 2:13pm
4
Could it be possible that the fan_timer may not be initialized and doesn’t have a finishes_at value?
Because, otherwise, the code seems to work:
germanm
September 15, 2022, 3:17pm
5
I was able to make it work!
Sharing in case somebody else runs into a similar issue:
This won’t work:
variables:
- choose:
- conditions:
sequence:
- choose:
- conditions:
But this works:
variables:
- choose:
- conditions:
sequence:
- choose:
- conditions:
value_template: '{% set remaining = state_attr(fan_timer, ''finishes_at'') | as_datetime | as_local - now() %}{{ remaining > timedelta(button1_duration) }}'
